RK 2.5 max flex vs 3.5 flex
Are these kits the same except for the 1" coil differance? The plan is to run 37" mtr's on a 2012 unlimited rubicon. It will have PSC aluminum tube fenders installed to help with clearance. Whats the thoughts on going with the 3.5 flex or 2.5 max flex?
unless you specifically want less flexy shocks, if you are choosing between the two, why would you want the 2.5? its litterally the same parts, both are progressive springs, control arms and a track bar with brake lines. the biggest difference will come to what shocks you get. the 3+ lifts usually let you get more flex from a shock then the 2.5 (in the case of their recommended shocks its 11 inches of travel vs a foot of travel). i mean the 2.5 max is a great kit, but for the exact same price, i cant help but think most people would prefer the taller lift
If you're going to run 37's I would think you would want the 3.5".
I'm probably getting the 2.5", but that's because my wheels are 33". I will probably get 35's in the future, but for now 2.5" will be right. If I do 35's, I would probably get flat fenders.
I spoke to David at Northridge 4x4 about it, and based on his advice, I got he 2.5" lift for my current 35"s with plans for latter down the road running 37"s w/flat fenders. I like it for the lower center of gravity. Just make sure you have appropriate bump stops, and you're good to go.
