RK front lowers
Quick question. My front lowers are a little cocked to the side on the front where they connect to the axle. It's a 2.5" RK Max travel kit. Can any of you upload and pics so i can compare?
The Bushing at the frame side of the arm should keep the arm going right where it should. As far as the Krawler joint goes it is supposed to be perfectly square in the mount and not cocked to one side or another.
I set it to the correct length required by the lift instructions so it should be right. Is there any reason why they would be cocked to the side where they meet at the axle
