RK Offroad Pro Long Arm Length vs Other Brands
#21
@ Rock Krawler I would be interested in whatever accommodations you could make for someone willing to move the mounts up. I would definitely be willing and able.
#22
I have stock arms still. That's what's wrong lol. Driveshafts also. Ride is too high for stock arms. Arms bind, on road is harsher than it should be with the angles the arms are at. The raised axle side mounts would help that. Thought about EVO kit but read too many people saying the kit is very hard to install and instructions hard to decipher. And that things don't fit well. Shafts rubbing or getting stressed too much during articulation. I plan on custom tuning coilovers that's about it on this jeep. I'm sure after it's paid off I will get crazy with it. But that will be down the line
#23
Pinion angles can be well controlled for a given range of travel using link synthesis as we have done. Our front arms are on point and pivot about the yoke of the driveshaft, but in the rear and especially on a 4 door, carrying arms that far forward could negatively impact the cross over angle so we chose not to do so. If you are willing to build your own system and remove all the constraints that come around the factory gas tank and other things that keep your vehicle street legal in all 50 states then the sky is the limit as dirt man stated. But be sure you have the talent and pocket book to do so. Otherwise, you will find our products very hard to beat. Personally, for the DD/Weekend Warrior guy the X Factor Setups are the way to go. If you want to simply pound on your Jeep, then the Off-Road Pro kits are the way to go...
Good luck with your build.
RK
RK
From what I have seen from mikes posts is that he wants a LCOG build that allows a lot of up travel to full stuff the tires into the fender wells. I don't think the 3 link with the tall rear bridge is going to perform that way.
#24
Former Vendor
If anyone wants us to do something a bit custom for them, please give us a shout. We are more than happy to help out. We have 2 Engineers on Staff that can help you with your geometry and anything you might want to meet your needs.
RK
RK
#25
Pinion angles can be well controlled for a given range of travel using link synthesis as we have done. Our front arms are on point and pivot about the yoke of the driveshaft, but in the rear and especially on a 4 door, carrying arms that far forward could negatively impact the cross over angle so we chose not to do so. If you are willing to build your own system and remove all the constraints that come around the factory gas tank and other things that keep your vehicle street legal in all 50 states then the sky is the limit as dirt man stated. But be sure you have the talent and pocket book to do so. Otherwise, you will find our products very hard to beat. Personally, for the DD/Weekend Warrior guy the X Factor Setups are the way to go. If you want to simply pound on your Jeep, then the Off-Road Pro kits are the way to go... Good luck with your build. RK
PR 44 and PR 60
Matthew
#26
Former Vendor
