Rock Krawler 3.5 in flex lift with Bilstien shocks, how's the ride.
#21
Former Vendor
Metal Cloak in this video rates their standard joint at +/- 17 degrees. They have them in several shapes and sizes. With a digital angle finder in a moch up control arm mount, we achieve the dimensions in the aforementioned post.
https://www.youtube.com/watch?v=8dE_tFFvjfU Thank you for pointing out the verbage under the Flex Joints. They are still shown on the website for service parts and does not relate to the Pro Series products at all. We will task our in house marketing people to try to update the verbage as it relates to older service parts.
We provided as accurate information as possible and did not provide any "opinions" with relations to the joints. We feel people can make their own decisions based off proper information.
We will not turn this thread into a pissing contest between Dirtman and RK. It is not worth the time.
RK
RK
#22
Former Vendor
First off I want to thank you all for your input. I'm fairly new to this and I'm trying to do this as right as possible. My Jeep currently is on a teraflex Leveling kit , I have a Smittybilt xrc bumper up front with a 10,000 lb synthetic rope winch, I have changed the wheels and they have 4.5 inch backspacing. I am running the stock mud terrains now but want to go to 35's. I take it off road here in Wyoming and use it to get to fishing spots. Would like to do a trip to Moab along with some places in Colorado. At first I was looking at a 2.5 inch kit but thought I might be better off with the 3.5 inch kit. After reading the replies I'm thinking the 2.5 inch might be the better choice. If that's what I decide to do will that save me from having to change as many parts? I'd like to stay around 1500.00 for the lift initially. maybe spend more down the road as I can. Just want it to drive and ride as close to normal as possible . I'm sure you guys see these kind of questions over and over and I really do appreciate your help.
#23
RK
RK
Their video on the comparison of joints with a JK arm shows 20.2 degrees of misalignment. I am just saying this because we want things to be accurate and not cherry picked right?
#24
Didn't mean to stir things up, just trying to figure out what would be best to spend my hard earned money on. I guess one question I have for Rock Krawler would be, do you stand behind your product or will it be a hassle if I have a problem with any of your parts. I'm a little concerned about the sagging issue. What will your company do if I have that problem. Seems like other companies have better warranties. I only want to do this once and want it to last. I will give you credit for being on this forum and answering my questions.
#26
Former Vendor
Here is link to our warranty policy and we stand behind it 110%
Rock Krawler Suspension
RK
#27
Former Vendor
If you want us to state advertised misalignment for these joints we certainly can...
MC - +/- 17
RK Pro Flex - +/- 15
Dual Durometer - +/-15
Then you can look at total misalignment advertised per arm assembly (lower control arms only)...
RK - +/- 45 degrees (Standard X Factor Arm Construction - Pro Arm Construction is +/- 60 degrees)
MC +/- 37 degrees
DD - +/- 30 degrees
Sorry our results did not match exactly for some. We would not argue about being off 2 degrees either. That is certainly not the point.
RK
#28
I think the Pro flex joint doesn't get love because its only used on one end. Its not a primary joint thats considered when someone is choosing arms. Comparing based on how its used is apples vs oranges.... OR green apples vs red apples LOL
#29
Former Vendor
RK
#30
That could be true! We have always put the Pro Krawler Joints at the axle because that is the joint location that does 90% of the work and we feel that needs to be the most durable. The frame side does not require nearly the misalignment the axle end does as long as the axle end does not run out of misalignment. But with people who do not really use their Jeeps off-road, that really does not matter much... RK
