rock krawler 3.5 mid arm flex or rancho 4" crawler system?
i'm trying to decide on what lift to go with .
i like the rk 3.5 mid arm but i also like the rancho 4" crawler system.
i will be running 35's and chopped fenders with either lift.
also i have stock shafts and idk if that will be a problem with the 4" rancho lift.
just for good measures i have a 2 door x 6 speed.
does any one have any good advise? thanks.
I basically have a mid arm 3.5 and you will need drive shaft. I would definetly go back with another one of their lifts if I got another Jeep. Rock Krawler tech support has always bent over backwards to help me with any problems.
alright thanks for the advise. i will definitely go with the rock krawler then.
will the 3.5" lift give me a good amount of ground clearance with 35's?
What I mean is the lift gives you room to fit a larger tire. The tires is what will raise the axle higher giving you more ground clearance
Former Vendor
The tires are what gives your axle the ground clearance and they will also give your chassis some ground clearance.
The lift will give you room for larger tires and will also give your chassis some ground clearance.
We have the RK 2.5 X Factor Plus on 33's right now. 35's will fit with no problem at all on the stock fenders. We now have flat fenders so a 37" tire can fit. I believe we will be upgrading to 37's soon.
