Rock Krawler Suspension Open Tech Line for JK Forum Members
#21
Former Vendor
RK
#22
Former Vendor
I just ordered the 2.5 Stock Mod kit for my 2012 JKU and I wanted to know if I will need to extend the brake lines or if I will need to do anything with the rear tail pipe? I thought I read that it may need some modification on the 2012 and newer but that may just be for the 3.5 kit.
Thanks for your help
RK
#24
Former Vendor
RK
#25
Former Vendor
RK
#26
Former Vendor
Former Vendor
A buddy of mine runs it on his 2 door with same results. He's actually taller with a 2.5" lift than my JKU on a 3.5" lift. The issue is the front progressive coils have zero weight to compress the first 3 wraps or so. Throw on a heavy front bumper and that will take care of your reverse rake. They make the coils like this so you don't get sagging with heavy bumpers. Unfortunately when you aren't running them, you get the results you are seeing. It's more pronounced with the 2 doors since its a lighter vehicle as well.
RK
#28
Former Vendor
I am going to be ordering the 2.5 stock mod with bilstine 5100, extended break lines, bump stops and exhaust spacer. I have a ' 12 JKU Sport and will be running stock wheels and tires, do I need any thing else. Thanks for your help.
Sent from my MB855 using JK-Forum
RK
#29
Former Vendor
I recently ordered a 3.5 x factor and will be returning from deployment in about a month to install it. I'm trying to use this time to figure out the "little secrets" for this lift. Are there any special tools or anything that anybody would suggest to make it easier? Any tips? Tricks?
Thanks
Taylor
Thanks
Taylor
RK
#30
Former Vendor
Will be buying your 2.5 stock mod system with rk front lowers and rear uppers. I have a rubi and would like to have a fix'd length sway bar links.( I've noticed the adjustable one don't seem to hold up to great at full flex)Could you tell me the fix"d sizes or possibly sizes for the front and rears or tell me another route, I don't wanna loose the e-disco.
RK
