Sponsored by:
Sponsored by:
Rock Krawler Suspension Open Tech Line for JK Forum Members
Old 07-07-2017, 12:43 PM
  #681
Former Vendor
Rock Krawler Suspension's Avatar
Originally Posted by Pale Rider
Hey, hoping this isnt too far out of your lane but I picked up the older version of RK's tie rod, where the radius is in the rod itself and the TRE's are straight..in this case Moog. I am looking to replace the TRE's and wondering if there was any information as far as if RK offered a TRE that would work or even the ID of the Tie Rod so I know what to look for when reaching out to Moog for a replacement.
Larry
They just take Factory Moog Replacement Ends
RK
Old 07-07-2017, 12:45 PM
  #682
Former Vendor
Larry
Can you provide us with a picture of the bar you have? chad@rockkrawler.com
RK
Old 07-10-2017, 05:41 AM
  #683
jgraz's Avatar
Hey RK
I just had a 2.5" Flex with Bilstien 5100's installed on my '16 JK 2d. I opted for exhaust spacers as well. Of course the spacers dropped the exhaust crossover below the trans crossmember which will in turn will hinder skid install without modification effectively lowering my clearance. I have read in several places and also had my installer tell me that the 2.5" flex does not need exhaust spacers to clear the drive shaft when installed on the JK 2d. I also noticed on your site this wording:
-For 2012 and newer models an aftermarket front driveshaft with 2" O.D. steel tubing is recommended, but not required.
So I figured I'd go right to the source, so what are your thoughts? If I kick the spacers, will I rub the stock driveshaft if disconnected? I know a new DS is in the cards but its a ways down the road at the moment and armor is next up.
Thank you in advance
Old 07-10-2017, 06:00 AM
  #684
Former Vendor
Originally Posted by jgraz
Hey RK
Depending on your shock length, if you went with our shocks or the recommended bilstiens you should not need it!
RK
Old 07-10-2017, 06:34 AM
  #685
jgraz's Avatar
RK
My installer went with the recommended Bilstien Rear -24-146715, but in for the front I have Bilstein part#24-186872 which according to some searches appear to have the exact same specs as the Bilstein 24-186995 that is on your site.
So if all is right, I should be able to pull the exhaust spacers and not have contact wit the stock driveshaft even when disconnected?
Old 07-10-2017, 08:06 AM
  #686
Former Vendor
You should be fine! You can certainly give it a try and go full droop and see if you have any contact!
Old 07-16-2017, 10:14 PM
  #687
Firedawg16's Avatar
Default newb quesiton.
newb question. I have been looking at the RK 3.5 systems. and trying to decide between the x factor and max travel, but cant really see a big difference. can you dumb down the major pro v con of the two kits? ive seen several jku runs 37s with stock fenders, not much flex room until flat. guess mainly I'm wondering what makes a 1k dollar differenc ein the two? Thanks in advance!
Old 07-17-2017, 12:31 AM
  #688
BoraBora's Avatar
Components. The Max Travel only includes the front lowers and rear uppers. The X Factor includes all 8 arms, coil wedges for the rear, and an adjustable rear track bar.
You should also ask yourself whether or not you really need the 37's. Are you running stock axles?
Old 07-17-2017, 05:48 AM
  #689
ShutterBug's Avatar
What BoraBora said.
But also, the X-Factor rear control arms are designed to push the rear axle back an extra inch to re-center the wheel in the wheel well.
Old 07-17-2017, 06:10 AM
  #690
Former Vendor
Sorry I have been out of the office for a few days.. but they nailed the response! If you have any other questions feel free to ask them!
Thanks RK
Quick Reply: Rock Krawler Suspension Open Tech Line for JK Forum Members
