Rock Krawler Suspension Open Tech Line for JK Forum Members
#991
I wonder who you talked to, all they have to do is substitute the 3.5" coils for the 4.5" coils. Its not like they put everything in the kit into one box. The components all come in their own boxes. You can also buy every component they offer if you wanted to piece the kit together yourself with 3.5" coils.
#992
#993
I read where it goes both ways where its not necessary and is. From the people who did install, I have heard nothing but great feedback. I read alot of threads and of people who had installed them. I spoke to a few JK owners who had 3.5 lift and switched to 3.5 Long Arm, and they all love it. I have compared Short Arms to Long Arms and I understand the difference. My wife doesn't like how my JK handles on the road so I rather upgrade my suspension which Long Arms corrects the geometry of the lift. To better understand, there are Youtube videos.
#994
Nice. IDK who I talked to, but I'll give them call again.
I think you can correct the geometry of the suspension with adjustable links that are a standard length. Metalcloak has a link kit that has their duroflex bushings too.
#995
As far as I understood, a long arm only allows for more articulation. With a 3.5” spring you may run out of spring expansion before you run out of flex which would defeat the purpose... or do I have it wrong?
#996
Long arms do not add articulation. They run on a flatter curve which reduces axle shift. Thats about it. Better tracking down the road is the main benefit. That and it lets you brag that you have a long arm kit. Good geometry on a short arm can give you a better ride at lower lift heights without the issues of clearance and the expense that long arms give you. Almost no long arm kit offered out there has good geometry either. Some hang the lowers under the frame and really give you clearance issues, some use long lowers and short uppers that creates some pretty good pinion changes during articulation. while the frame side brackets will be changed out due to the length of the arms, the brackets are put "where they will fit" and not for geometry purposes. You will see most front brackets have very little separation, rear brackets are all over the place and you have the fuel tank that is in the way for a well designed kit. Almost nobody moves the lower axle side brackets to adjust the geometry either. Most people that buy a long arm kit do so because they want a long arm kit but cannot tell you anything about why they should run one. It's their money and their jeeps so they can do whatever they want.
Your articulation will be determined by your shocks, bump stops (tire clearance), and your driveline.
Sv_dude (05-29-2020)
#997
Former Vendor
Here is one example of those kits. JKU 3.5 Inch Adventure-X Long Arm System - Rock Krawler Suspension
jadmt (05-29-2020)
#998
Sorry, fixed for you.
How is your 3 link cracked frame cover up going? Still using the Chinese bat flu as an excuse not to notify customers? How many cases have you had so far? Never mind, you would just lie about it anyway.
#999
I do find it pretty crazy that Rock Krawler still hasn't just pulled a report of everyone who purchased their 3 link long arm, and mail and emailed them a basic, "hey while there haven't been many cases, please check your rig for xxx." I'm lucky I stumbled upon that thread on the other forum, and alerted my friends running RK 3 links. Mind you, I was 2 months late to reading that thread, and when I told my buddies...they hadn't heard anything about this.
Step it up RK. Take accountability.
#1000
