Rock Krawler Suspension Open Tech Line for JK Forum Members
#111
Former Vendor
RK
#112
Former Vendor
RK
#113
Former Vendor
RK
#114
Former Vendor
We may need more than one thread!
I have a 2012 Rubicon on a BDS lift. I believe it's 3". I know this because I'm fitting 35s nicely, and because the Fox Shox stickers say "BSD" on them.
Anyway; that's the background. That and those stupid brake line relocation brackets. (I have longer brake lines on order, and will be fixing it right shortly).
Also, I had a 5.5 Longarm kit on my last TJ from RK, and it was AWESOME. It worked well on road, and off road, it was CRAZY how much it would flex. It needed retainer springs up front, and limiting straps all around! I rarely needed my lockers, as it's flex meant it was always planted.
So, my question;
I LOVE the way my BDS kit rides ON-ROAD. But from what I can tell, I have all stock control arms. The track bars also look stock and look to be on brackets.
I'm not looking to change the height, (all spring lift, no spacers). I'm also no looking to change the ride (the shocks seem to work very well).
I AM looking for some more flex and to ditch the stock control arms.
Is there any reason I can't build this as I go? For example, install 2 new lower front control arms from RK, then install 2 rear lower, then install 2 front upper, etc?
Is it not ideal to mix makes? If it was my Jeep, I'd have gone strait to RK, but I bought the jeep like this, and the dealer said they'd give me the full 3/36 warranty on everything... so... there's that lol.
anyway, I love the videos, love the products, and love the color PDF installs. Keep it coming! the more I know about your products before I buy, the more likely I am to BUY.
So, my question;
You can deffinitly upgrade your control arms as you see fit! Front lowers would also be our first purchase, then if looking to get both uppers and lowers in the rear we would suggest that you purchase them at the same time so you can get the 1" stretch in the rear like our x-factor kits.
RK
#115
Former Vendor
RK
#116
Former Vendor
I run my jku on 3.5max travel on Fox piggybacksfactory series sitting on 35 inch toyo's aired down to 28 psi. But everything seems to be really rough like every bump I hit is unbearable and it sounds like a clicking sound coming from either the upper shock mount or spring perch area everytime I hit a bump
I used to run a teraflex 2.5 coils lift and changed it out for those exact reasons above and some other limitations.
I have checked all the torque specs on track bars and control arms and they are good. Also had the jeep aligned and was actually told I was barely off.
Any recommendations?
RK
#117
Former Vendor
Former Vendor
Thought I would ask sorta a dumb question. On the rear track bar I have it set to length 39 3/4. 3.5 dual sport life. My question is that length doesn't seam to work for me. I had to go about an inch longer is this a common thing? I know those are starting measurement in your instruction, but what would cause it to change that much? Control arms are to lenght just check everything again.
RK
#119
Former Vendor
1. I have a 2.5" stock mod + LCAs on my 2013 JKU and my springs are all oriented the right way (rear springs have the part# sticker facing back) and my right rear dips a little, maybe half an inch. Any other tricks to get this to even out? I have a quarter of a tank of gas and it's still dipping. I have no other bolt ons besides my full size spare (33 tire on 15 aluminum wheel mounted on stock carrier).
2. The instructions state to remove the rear sway bar links when installing the lift, but that's it. Should these be reconnected? I reconnected mine afterwards. I know some kits require moving stock front to back or vise versa, but my kit has the disconnects up front, so if it's the latter then I'll pass.
Is #2 possibly the cause for #1?
RK
#120
Former Vendor
Hey RK guys. I'm trying to decide on which RK lift. I'm pretty new to all this so excuse me if I ask something lame.
I have a 2009 Rubicon 4dr and I'll be running 35 inch tires. I don't have a winch and bumpers yet but plan to do both, including tire carrier and possibly a roof rack, in the near future. It will be not only a daily driver but something I work out of 3-4 hours per day (not all driving) so on road and in town drivability is really important but I want to be able to four wheel some pretty gnarly (I know that's subjective) stuff too.
I'm looking at either the 2.5 max travel or the 3.5 flex. Both appear to consist of the same components (obviously sized differently) so what difference is there other than height? Am I going to get more articulation with a max travel or is it only a max travel as compared to the 2.5 flex? I'm not really concerned with the look as both will look cool enough for me but I do want the best performing system.
Thanks
Archie
Thanks
Archie
The two lifts that are in question like you have stated, Are the same basic componants other then the coils and the sway bar link center pins. The only thing that is going to allow one to flex more then the other would be what you choose for shock travels. With the higher lift you will be able to run a slightly longer travel shock package.
RK
