Rock Krawler Suspension Open Tech Line for JK Forum Members
#221
#223
Jam Nuts
The current instructions suck man. You can get by with them but they really suck. As for the jam nut. Just put blue or red lock tight and tighten them as much as you can. I check my nuts after every trail. Lol. So if one is loose just re-tighten it.
If your asking about adjusting the control arms on the jeep. The instructions give you measurement to set the control arms to before installing them. Mine were dead on. If you have any other questions shoot me a message.
#224
Can you post a pic. I can do the same.
#226
I have the 2.5 X factor lift waiting to be install am in the process of wheel shopping and the guy at the tire store told me they put 9 inch wide rims on with an 18mm offset all the time with 35x1250s will this work??? Wanting to go this route because of inspection laws here in WV
#227
If you have any doubts on the wheel / tire combo just get the tire dealer to mount one wheel tire that you choose and test it on both sides of the front axle to see if it rubs anything before you pay for anything. If they want to make the sale they will at least mount one for you unless the wheel is an order only item.
You are going to love the 2.5 x factor. 35 x12.50's will rub a little on the back of the rear wheel well inner fender. I think I will end up trimming my fenders but think the pinch seam in the front of the rear wheel well is going to be ok.
#228
#229
Brake lines
New question about the front brake lines that came in the 2.5 max kit. I think they are these.
Wrangler JK Brake Lines
The bracket that mounts to the frame is the same for both sides. Which seems to make it backwards and opposite for one side. Hard to explain put on the passenger side it is orientated with the brake line hole on top and the frame mounting hole on the right (towards the front). Everything lined up good and fit nice. On the drivers side, it mounts and lines up poorly. With the bracket orientated with the brake line hole on top and the frame mounting hole on the right (but towards the back in this case), the hard brake line connection is to far away. Same issue if I flip it with the bracket orientated with the brake line hole on bottom and the frame mounting hole on the left (towards the front), he hard brake line connection is to far away. I try to get pictures as this seems difficult to explain clearly.
#230
Can't you just remove the end you want to work on and let it hang down and tighten the jam nut then just push it back up into place?
