Rock Krawler Suspension Open Tech Line for JK Forum Members
#41
Another member on here has his RK drag link hitting the track bar bolt on your drag link flip kits track bar bolt. I had the same , but I added washers to the steering stops to prevent it. My RK lower control arms are at their shortest length at a 4.5 inch lift and my upper RK's are dialed in for a perfect pinion angle for my DC driveshaft. Is there anything else we can do to prevent the contact?
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=456226"/>
#42
Attachment 456051
Here is a picture. To me it looks like it sits higher in the front. Could be my eyes playing tricks on me.
#43
Can't decide what to do. I want to replace my spacer lift with a coil lift. I have a Warn Elite bumper and M8000 winch which dropped the front about an 1". The spacers are 2.5" front and 1" rear which brought the JK to level. This is on a 2dr with softtop.
What I'd really like is about 1/2" drop/rake in the front -- so when I load a 200-300 lbs of camping gear in the back it stays level.
When I look at the RK springs on JKs with a heavy front bumper/winch, it appears like the upper part of the coil is almost totally compressed. Doesn't that negate the purpose of a dual rate coil? So, why not just go with a normal coil like Teraflex/OME? (Asking this for info, not to be critical of RK.)
#44
I have a 2011 JKU Rubicon, which apart from a couple of skids is basically stock and I'm looking at your 3.5 Flex System and 15" MB TKO wheels with 35" MT/Rs.
Anything to watch out for with this combination?
#45
I just bought a 2.5 max travel kit, and i was wondering if i need to extend the axle breather hoses? thanks for the help guy, looking forward to getting the lift on in about 2 weeks
#46
I have a 2.5x-factor on my '12 2dr rubi. Stock rear bumper and spare. There is only about 1" clearance between trac bar and exhaust pipe and everytime I hit any kind of bump, dip, pothole etc. they bang together. The coating is almost gone off the trac bar. Needless to say its annoying having to slow down for every little thing. Any suggestions? What options do I have? Thanks in advance!
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=456171"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=456172"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=456173"/>
#48
Former Vendor
The rear has a stock bumper. It does have a 35" Trail Grappler which is heavy, but so does most other lifted Jeeps. So the only way to level it out is to load up the front end?
Would the spring correction wedges do anything for me? Should i consider a spacer in the rear?
thanks for the reply!
Our rear spring wedges are designed to alleviate some of the spring bow that the rear JK coils have. This wedge will indeed net you a small amount of lift height due to the fact that when it straightens the coil more as well as gaining .25"-.50" from the thickness of the wedge. A spring spacer would also be an acceptable way of remedying this.
RK
#50
Attachment 456171
Attachment 456172
Attachment 456173
Attachment 456171
Attachment 456172
Attachment 456173
I haven't seen a response on this... (Since it's been a while I thought I would bump it up) I would kinda like to see an answer before ordering my lift.
