Rock Krawler Suspension Open Tech Line for JK Forum Members
#861
Hey Adam, can you locate a part number for me? Or even a link to a set of your drag link ends? I just went hydro assist this week, and it’s time to replace them. I believe I have your Gen 1 drag link. It had non greasable ends on them, but I would definitely like a greasable set on them. Please let me know if you have any questions, or need any other info. Thanks!
Here is a pic of mine:
#862
Former Vendor
You'll want to use the tie rod end that is designed to go into the factory location at the pitman arm. Most aftermarket replacements are greaseable.
#864
Former Vendor
Rock Krawler Suspension (10-03-2018)
#866
Just installed 3.5 rock krawler coils
How’s it going? I just installed 3.5 rock krawler coils. Changing from 2.5 teraflex.
My question is I have the new coils in and I’m getting that flighty feeling up front at highway speeds. I also have adjustable control arms all around. By any chance do you know what length the control arms should be at top and bottom front and rear for your coil springs. And should I adjust or have my Jeep professionally aligned ? Will they adjust control arms ?
Thanks
Thanks
#867
Thanks
Thanks
#868
Thanks
Thanks
At 3.5" of lift, you might also look into a drag link flip.
#869
^^ caster, not camber, right? Camber is bj's which also may need love but with adjusting height you're looking at caster changes which an alignment shop can fix with adjustable arms.
#870
