Rock Krawler Suspension Open Tech Line for JK Forum Members
#881
There is a way stretch the wheelbase without buying the lower rear arms but reqires a bit of cutting and welding. You also dont need to buy new perches as you can retask the factory ones that are cut off. If you can weld you can also (or have a good shop) just build new arms that are better and use better joints. With the RK arms you are limited to their joints or heims.
#882
Before I do all that I’m gonna confirm which part number I have since their still in a box and ask them to exchange them or just upgrade to a more upgradeable manufacturer.
#883
Former Vendor
Adam C
#884
Former Vendor
That individual part would be a direct sale, they are not a mass produced item anymore, I'll gladly make another set. They were only used on 1.5" X Factor kits, and that sku set has been dropped.
#885
Since only the 1.5” x kit had those perches would I have to weld on different perches if I wanted to go to a bigger lift eventually?
I don’t see a part number on my rear lower arms but the sku number on the is RKJK15MT-4 are these too short for the one inch stretch?
I’ve determined I’ll only do the stretch if I don’t have to replace the arms.
#886
Former Vendor
Yes, the Max Travel kits that came with the lower arms ARE too short to push the axle back.
If this is a recently purchased kit, your retailer owes you proper components, no retailer of ours should be selling inventory that is over 6 years old.
Adam C
#887
Nice I bought it this summer. Would you be willing to exchange them? I don’t mind driving to ny and like that I can also get the perches from you too or otherwise I’m not gonna bother.
#888
Former Vendor
Adventure Series
Hey guys,
Is the max travel discontinued now? Has the adventure series taken its place?
Anyone running an adventure series lift yet?
Cheers
Cheers
#890
Former Vendor
Max travel is not discontinued, Adventure Series is a line that parallels our X Factor series with a bit more vibration dampening material in the arms, brake line drop brackets (where applicable) and more simple rear sway bar links, this makes install faster too.
