Rock Krawler Suspension Open Tech Line for JK Forum Members
Old 12-20-2018, 02:16 PM
  #921
Appauldd's Avatar
I gave it a workout last weekend. This is where I found out it takes a beating....but also hits the body mounts.
Appauldd is offline
Old 12-21-2018, 05:44 AM
  #922
Sponsoring Manufacturer
RockKrawler Representative
Rock Krawler Suspension's Avatar
Hell yeah, looks great!
Rock Krawler Suspension is offline
Old 03-15-2019, 05:29 AM
  #923
Ocotillo Boy's Avatar
Thinking of doing a 3.5" X Factor kit to my JK 2 door. What is the optimum wheel and tire size?
Ocotillo Boy is offline
Old 03-15-2019, 06:07 AM
  #924
TheDirtman's Avatar
You pick a lift to accommodate tire size not the other way around. Lifting for the sake of lifting does little for you except empty your wallet. Any lift that raises the vehicle 3.5" should accommodate a 37x12.5" tire on a 3.5-4" back spaced wheel. 17" wheels will give you the most options in tires to run. IF you are to run 37's at 3.5"+ of lift expect to do some axle reinforcement/upgrades, drive shafts, high steer, and new axle gears.
TheDirtman is offline
Old 03-15-2019, 10:41 AM
  #925
Great answers from Dirtman.
The real question is, what size tires do you want to run and what do you do with your Jeep?
Old 03-16-2019, 08:19 AM
  #926
i would like to run 37's for ground clearance but I'm not sure the optimum backspace I should use is what I was trying to ask.
I should have phrased it better.
I am bouncing back between 35's though.
Old 03-16-2019, 08:31 AM
  #927
TheDirtman's Avatar
For a 37x12.5" tire you should be looking at 3"-3.5" BS. It really has nothing to do with width. Ideally you would run a 9" wheel with 4.5" BS for good steering and run a wider axle. Throwing that big heavy tire that far out is tough on the unit bearings and ball joints.
Old 03-16-2019, 08:32 AM
  #928
i want to be able to get through a fair share of trails without a lot of drama. Doesn't really matter what I do to it because it's not my daily driver. It's just a toy.
im torn between the 3.5 X factor midarm w/ 35's and the 3.5 X factor long arm w/ 37's and flat fenders
Old 03-17-2019, 06:31 AM
  #929
Wrangeler X's Avatar
I'm looking for extended and collapsed lengths of 2.25 RRD shocks for 3.5" lift. Rear jk. Need to compare against my 10" travel 2.0 RRD w/resi shocks.
Anyone know?
Wrangeler X is offline
Old 03-17-2019, 12:45 PM
  #930
Default Max Travel Install
Hi guys, Just installed the 2.5 max travel recently.
After setting my rear upper CA straight in the bracket and torquing everything down, it seems to sit cockeyed after driving.
Lengths are set as per recommendation for 2.5" lift and have had an alignment. Is this normal?
after driving
after driving
Npeeps is offline
Quick Reply: Rock Krawler Suspension Open Tech Line for JK Forum Members
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
