Rock Krawler Suspension Open Tech Line for JK Forum Members
#941
#942
Rock Krawler, I just finished installing your x-factor long arm upgrade, and I’m looking at the rear lower arms and noticing the arm/jamnut is contacting the axle side mounting bracket on both driver and passenger sides. This appears to be a result of the arms being straight and mounted outside the frame, and the axle side mounts being oriented a bit diagonally toward the inside of the Jeep, or toward the differential, if that makes sense. What can I do to remedy this? I’d rather not cut out the axle side bracket as it will lose structural integrity, and I’ve driven myself crazy with all the plasma, sawzall, and grinder cutting I’ve done over the past 3 days.But I see no other way to fix the issue. I’m on your 2.5” triple rate coils in the rear, with about 3.5-4” of net lift in the rear. Help is appreciated.
Side note, I haven’t driven the Jeep yet after the install, much less wheeled it, but it appears the rear lower arms will contact the rearmost frameside body mount upon upwards articulation. This may not be the case, but it LOOKS like it will be. I am absolutely opposed to limiting my uptravel with bumpstops to prevent this from happening, but feel like clearancing the body mount would be sacrificing structural integrity there as well.
#944
Former Vendor
Shooting from the hip without seeing pictures:
If you have an X Factor long arm, which reference point did you use for the rear lower control arm mounts on the frame? If you used the oval shaped hole and aligned there, you'll likely have no issue with contact depending on your rear shock mounting locations and rear shock lengths. If you chose to mount vertically higher on the frame, yes trimming of the body mount would be required.
On the axle side of the rear lower arms, first, make sure the axle is centered in the wheel well, both left/right but also front/back. if the axle is too far forward and arms are adjusted too short, you will have the problem you described. These will also be affected by the placement of the rear lower frame side mounts.
#945
#947
Former Vendor
Mike, have you cycled the suspension yet? If you've trimmed the fenders to increase uptravel, you'll likely need to clearance the body mounts as well.
#949
Full flares or not, those arms are going to hit the body mount. I think what he's trying to tactfully say is "What the hell, why doesn't the system work how it's supposed to when I've done what you've asked me to do. Why do the links contact the body mount-not mentioned in the install notes."
#950
Former Vendor
