Rock Krawler Suspension Open Tech Line for JK Forum Members
#981
[QUOTE=Rock Krawler Suspension;4354319]Adventure Series has been around for almost 2 years in production, in testing for a long time before that. It has fixed lowers so no jam nuts to worry about on the arms and has quite a bit more bushing material than the X Factor series which results in a bit more of a plush on road ride. The series 2 has adjustable rear uppers while the series 1 uses factory uppers. The series 2 has the ability to fine tune the rear pinion angle which helps to better support weight and get the springs to truly stand up as they should. The determination in how critical that is, is up to you, it is something you can always add later if you started with a series 1.
The X Factor tends to be the choice of most offroad enthusiasts, who also tend to be the ones doing videos...[/QUOTE
Thanks RK! Bought the series 2 can't wait
Rock Krawler Suspension (12-12-2019)
#982
I recently purchased a 2009 JKU with a rock krawler 3 link long arm (I believe part number is JK35XFLA4). It also has Evo bolt on King 12” coilovers.
I’d like to do a high steer kit on it, like your RK04505. My question is, the long arm kit came with an adjustable track bar that is nearly all the way compressed as far as adjustment goes; would the high steer kit work with this track bar? It’s the one included in the kit I mentioned above. Seems like it’s going to be far too long once the track bar bracket is raised a bit.
If my current bar is too long, which size bar should I get with the steering kit? Thanks!
Matt
Matt
#983
Former Vendor
Matt
Matt
#984
Which long arm kit is your that most people like, safer to install and budget friendly. I am looking a 3.5 lift. Will that be enought for 37s? Also, I have MC flat fenders, Adams front and rear drive shafts, G2 axle RJ Dana60, and Tera Prorock 44 front axle. Will certain kits not work on this ?
#985
IF you already have the MC fenders you should be looking at A metal cloak lift with the 6 pack shocks. Even the short arm MC will give you way more flex and a better ride than any of the RK lifts either long or short. Your axles should not be an issue.
#986
I read so many reviews on long arm comparisions to short arm kits such as metal cloak. Despite the headache of the cost money and installing these, people love them. Even the Game Changer. I have installed parts in the past where I wished I went another route, such as my previous Rugged Ridge fenders, so I rather go with the Long Arms. I just met a few who just installed them and loves it.
#987
Metal Cloak makes a long arm kit too and it is much better than RK. More travel and better ride. Their lock and load takes the bind out of the front the rear brackets give you better geometry over anything RK has to offer. BTW I don't have a Metal Cloak on lift on my rig.
#988
#990
