Rockhard rear bumper install...help!!!!!
I remember having some issues with that too. I got one in, but ended up leaving one out. Later after relocating the muffler, I took another look at it and easily got the other bolt in. The muffler is a real PITA to work around with those.
I had no issues with mine when I did the install. It did take some time to get it lined up right, however I didn't need to drill out the holes any larger. I can say that I'm very happy with this bumper and that it is one strong SOB. I have bashed the hell out of that thing and really no damage to speak of. I can say that I have a slight rattle in the tire carrier when I hit a large bump or pot hole, other than that its a great bumper. Good luck with your install, and if your like me when you start getting pissed
step back and take a break and have a cold one
then try again.
then try again.
ALL IS GOOD..... I took the bumper back off and put all the bolts through. had to realign the brackets that go into frame as they would not line up either. I also had to drill out both center holes ... alot.....and both side holes a little.....
love the look and the quality is high.... I guess maybe mine was built on frday at 4:59
all done and happy again!!!!
