rough country "xflex "
Old May 20, 2012 | 05:37 PM
JKguy07's Avatar
Default rough country "xflex "
Who is running the xflex systems? I have had nothing but problems with my flex joints and there customer service won't email me back. Anyone else have bad luck?
Old May 20, 2012 | 05:46 PM
jokerforever's Avatar
From: Minot, North Dakota--not by choice--I belong in Dixie
There's a RC rep on here. I'm sure he'll chime in as soon as he see this.
If not try to PM him.
Old May 22, 2012 | 05:38 PM
jortega3333's Avatar
I too am having problems with front to rear slop in the joints. I have the complete front and rear upper and lower set.
Not sure but I suspect the stock metrics bolts are too small and need to be a US standard size. Also waiting for a responce back from tech support.
Old May 24, 2012 | 07:16 PM
JKguy07's Avatar
I still haven't herd a thing I can't even drive it.
Old May 24, 2012 | 07:24 PM
I called tech support today and it sounds like i need rebuild kits for the joints...using the stock metric bolts is correct apparently. They did not answer my email so not sure why they even offer that as a form of communication.
Old May 24, 2012 | 07:57 PM
a4x4high's Avatar
I emailed them a question about a part of their install vid for the 3.5" series II lift 2 weeks ago and still have not got a response . I have purchased the lift and installed it this week and have had some issues but worked through them myself cause of the lack of reponse to my email. I hope if i have any further problems the response time is better .
Old May 25, 2012 | 11:56 AM
robinson86's Avatar
I have to bump this to see if they will respond to your problem. I installed the 3.5 system with their dual stabilizer and the passenger side unit was contacting the tie rod or track bar bracket. I'm still waiting for a response to that
Old May 25, 2012 | 01:42 PM
jimk403's Avatar
I can never get through by email. Give them a phone call, they will help you.
Old May 25, 2012 | 02:29 PM
grumpy1's Avatar
I hate to say this but you get what you pay for, and that includes customer service.
Old May 29, 2012 | 04:04 PM
JKguy07's Avatar
I was hoping someone from there would reply on here. I probably need the rebuild kits too but I'm not buying them because it barley has 500 miles on the lift its garbage
