Rubi transfer case swap
I'm about to search for a 4:1 transfer case from a Rubicon. I've got a 2011 6spd. Which cases will work and what years?? I've got 3.21s with 33s and I'm ok with the combo Except when offroad. Then I can't crawl slow enough at times.
I'm interested in responses as well even though I'm under the impression that all cases work with our manual. It seems like it was the auto where things got oddly specific.
Ok so the short answer is any manual 2007-18 will work.
Long answer 2007-2011 auto and manual transfer cases will work on your manual transmission. 2012 and up you can only use manual transmission transfercase. R/ Will |
Will,
I was thinking it was along those lines but there was an adapter on the front of the auto that we could pull off?? Admittedly, I haven't bothered to look since seeing the info causally pop up through the years. Investment, dude out of Michigan that runs Fusion 4x4 is the one with the info on it. |
That helps alot, thanks!
