Rubicon Express Bushings
Old Apr 30, 2010 | 08:20 AM
Default Rubicon Express Bushings
I bought and installed my RE 3.5 Superflex lift last March. Recently I was hearing some clunking, especially when taking off as well as some squeaks. I went to service the superflex joints and noticed 3 of the 6 bushings on the control arms were disintegrating. I called 4wd parts where I bought the lift and had the bushings in two days, probably because RE is located here in Sacramento. Any way I am planning on heading up to the Reno Whitewater festival next weekend and will be towing my pop-up, so I figure I better get busy and get the bushings replaced. I know this has been a common problem, so for those who have replaced the bushings what was the technique? Do you need a press to get the new bushings in, or would a vice and socket work? Anyone have problems with their new bushings failing? I don"t want this to become a yearly maintenance routine. Any tips welcome.
Old Apr 30, 2010 | 09:52 AM
sonja149's Avatar
Easy, I remove the old bushings with a press but it can be done with a hammer and a socket. I spray windex on the new bushing and give it a wack with a dead hammer it goes in real easy. Make sure that the bushing boss is round as they sometime stretch out. Rubicon has had a bunch of bad bushings and they has been a warranty issue on them.
Old Apr 30, 2010 | 01:05 PM
mkjeep's Avatar
Look on the bright side of things. You'll have to get brand new bushings every 6 months or so and you'll get good and faster at changing them out. And able to show fellow RE guys how to change their's too.
Old Apr 30, 2010 | 02:56 PM
No Superflex joints are good, they are on one side of all the control arms. It is the bushings on the other end that are bad. Just need to make sure I can get by without a press as I don't have one. If necessary though, I will pick one up at harbor freight, but besides this application, I really have not had much use for a press. Don't want something I use rarely taking more space up in the garage. I also could get creative with a bottle jack if I have to. Just looking for some input from those who have already had to do it.....and that seems like a fair number of people.
