Rubicon tire n wheel question
I want to upsize to 33" on stock Rubicon wheels but I want to go wide. Can I put a 33x12.5 on a stock Rubi with a spacer. Or 16" x 9" wheel replacement with what backspacing, and do I really need a lift? Budget requires minimal cost impact. What are you're recommendations? Function over style.
I have 37 12.5 on Rubi wheels with a spacer. Yes you can do 33s with minmal rubbing. Leveling kit would fix that.
Browse through the Wheels & Tires FAQ at the top of this section...
Q: What is the biggest size tire I can fit on my stock Jeep JK Wrangler? Q: What is the biggest size tire that I can I fit with a 2.5" Budget Boost? Q: What back spacing will I need on my wheels in order to clear 12.50 wide tires? Q: What are wheel spacers? My opinion: Get a levelling kit. TeraFlex, or look at Curries Long Travel leveling kit for a bit more travel Or a 2-2.5 inch budget boost. (even a 1" body lift would do it) If you like the stock rims, get spacers. If not, get some new cheap steel rims with a 4.5ish BS If a lift of any type is not in the budget, be prepared to do more trimming. Also check the write-ups on Chopping the stock fenders. That'll give plenty of room with no lift - but you'll still need to change the steer stops and trim the skid, etc. |
Just do it
Just don't go wider than 12.5 on stock wheels.
