Rubicon on X suspension help needed
Old Mar 12, 2010 | 06:10 AM
1908_Cubbies's Avatar
Default Rubicon on X suspension help needed
I need advice from some of you who have done the 4 door Rubi to 2 door X coil and shock swap... I have just finished doing the front and I am unsure if I should do the rear. My X had a 1.5 inch rake probably due to my bumper and winch. After I put on the front shocks and coils, I gained 2 inches in the front. Now I am off .5 the other way.
Should I leave it like this or should I do the rear also? If I swap the rear, will I end with the same original rake? I haven't looked at the rear coils to see how much of a difference there is in part numbers. In the font, I went from 13's to 17's.
Thanks!
Old Mar 12, 2010 | 06:35 AM
Joisey's Avatar
I would do it, with the 1'' spacer and rubi springs i gained 2 inches, with out the spacer it should level you out close to perfect.
Old Mar 12, 2010 | 06:51 AM
MasterG's Avatar
Originally Posted by 2k2wranglerx
here's a pic
Do you have your 1 inch spacer on this pic ?
Your rear look way higher.. no?
but nice JK
Old Mar 12, 2010 | 07:50 AM
MasterG's Avatar
that's with no spacers. the 1" should level it out to just about perfect.
fiew..
X2 then. Just add spacers.
Old Mar 12, 2010 | 10:27 AM
Thanks guys! I just finished the rear and it level out almost perfectly! Now the 265's do look too small... Time to upgrade!
Old Mar 12, 2010 | 10:31 AM
MasterG's Avatar
