From Russia
Hello. I do appologise for my english. I am from Russia and need your HELP. My Wrangler JK 2dr X (sport in russia), AT, 285/75/16 tyre had 11-14 mpg. IT IS 185 mile on tank. I love JK, this is my first JEEP, it is outstanding car, but i did not expect such mpg. I read some posts, guys wrote about 15-19, 14 mpg on 35 tire! I try to drive very easy, rmp 2000-2500. Is it normal?. Our Dealer says it is JEEP THING, hate them. (there also were some water leak, problem whith had light, and so on - they couldnt do anything)
Thank you all
Thank you all
Hi Filkovi,
Welcome to the JK-forum. I have 35" tires and I get about 10-12 MPG in a Rubicon. People do different Modifications that may get them better MPGs. What was on the Sticker from the dealer?
As far as the water leak, is it in the freedom top? if so, their is a lot of information on this site about that topic and other issues.
Hello Filkovi !
If you are able to make a visit to finland, these two dealers/maintenance shops can help you if you need to make repairs:
Autoportti Oy
Merikatu 6, Hamina
This is only 20 km from Vaalimaa border.
or
Autotalo Ripatti Oy
Toikansuontie 6, Lappeenranta
Hope this helps you !
Autoportti Oy
Merikatu 6, Hamina
or
Autotalo Ripatti Oy
Last edited by wayoflife; May 27, 2008 at 08:02 AM. Reason: please refrain from posting contact information to non-sponsoring dealerships
What are the specs of your Jeep?
Do you have the CRD and run diesel fuel, or are you on petorl like us.
What transmission?
Weather and do you go over a lot of hills or is it pretty flat?
Good job on your English.
oh, what mpg were you getting with stock tires?
What transmission?
Thank you all
Thank you all
I believe your tire comes up to 33 inches; If you have 3.21 rear axle or 3.73 that is about correct ..... prolly your gearing compared to tire height !!!
I went back to my stock tire .... and got 19 on the highway , but I did not go faster than 67 miles per hour !!! 70 mph kills the economy !!!
Thank you all
Thank you all
Maybe the real cause to think you are getting poor mileage:
Did you recalibrate your speedo for the 33" tires on now? What was the original tire size on your X, 29's?
I will guarantee it is a calibration thing your speedo is probably out by approx. 10-12% if you had 29's originally and therefore you seem to be getting crappy mileage.
You will have to figure out your true calibration (%) and hand calculate your distance by adding the extra mileage with your larger tires.
TEEJ should chime in on this...he has explained it very well in other threads.
Other things that may cause poor mileage:
What rear end do you have? 3:21/3:73 or 4:10?
What Octane fuel are you using? Recommended 87
Is your JK brand new very low miles? The motor will need sometime to loosen up and break-in.
What type of roads are you driving on? Mostly pavement or dirt roads?
Air filter is clean, tire pressures are correct.
However the Wrangler is a Brick on Wheels.
Thank you all
Thank you all
Nado snyat' freedom tops i pokrit' vsu rezinu na verhu seliconom.
Kakit problemi s perednimi farami?
Unless you have the speedo/odom recalibrated for the larger tires, you will not get an accurate odometer reading. I also have the 285/75/16, and at around 60 mph my speedo reads almost 6-7 mph slower than I am actually going. So your odometer will show less miles too.
