Say you were a couple of days away from civilization...
People buy Wranglers for many different reasons/activites -- I bought a Wrangler (4-door) for scuba diving, training my retriever, dog sledding, and canoe camping. In the next 2-3 years, I'm hoping to do a canoe camping expedition around Nunavut for a month or more. A lot of the places we'll be driving to have little or no roads and could be several days away from even the smallest of villages. We'll be driving over mostly barren terrain with small-med round rocks, soft muddy terrain, through small creeks, etc. I have a lot of the equipment figured out already, but I'm wondering how to protect/improve the Jeep's underside. I'll need decent millage and good ground clearance, but not the 4" lift kind of clearance. I was thinking more in the 2-3" lift with 32-33" tires. I like the FT Ultimate kit -- seems very robust -- but 3" might be a little much. I was also looking at the Solid diff covers. Should I consider additional skid plates? Should I mix the FT Ultimate kit (w/ or w/o Nitro shocks) with a 2" BB? Highway handling is also extremely important. :-) Your thoughts and suggestions would be greatly appreciated.
Thanks,
js.
Thanks,
js.
Don't mean to hijack, but how are you going to carry "several days" worth of fuel for this expedition?
This is actually a serious question -- even with two jerry cans it seems like you've got about 30 gallons max, which should be good for about 450 miles optimistically under off-road conditions.
I've been thinking of planning a multi-day thing myself and haven't even gotten to the armor part yet
It's a good question though, fuel would def. be an issue.
-E
This is actually a serious question -- even with two jerry cans it seems like you've got about 30 gallons max, which should be good for about 450 miles optimistically under off-road conditions. I've been thinking of planning a multi-day thing myself and haven't even gotten to the armor part yet
Supplies could always be dropped off by float plane along a few pre-selected lakes. If they could hit 2-3 lakes on a single trip, it might not be too expensive... Sounds like I'll have to start looking at maps and doing some fuel consumption calculations! :-)
Thanks,
js.
Thanks for all the great replies!
js.
If reliability is the prime concern, consider leaving the Jeep stock. Your Rubi comes on 32 inch tires with reasonable ground clearance. Instead, put your money into addition armor as it becomes available.
Since you have a couple years, and only want to go 2 - 3 inches, I would suggest you wait.
I have never run OME (Old Man Emu) lifts, but have never heard a bad thing aobut them. The only will do 2" (or so) lifts and focus on handling. It is the only lift offered that I have ever seen that you can choose springs for Light, Medium or Heavy loadings. All others, 1 spring rate fits all.....(or not). This lets you pick springs that will serve your load needs without sacraficing ride quality. They are not out for JK's yet, but I have heard they will be soon.
Other than that, if your just dealing with small to medium bowling balls, you shouldn't need too much. The more supplies you take, the more likely you are not to need them. Murphys law at its best!
[snip!]
2. Spare axle shafts. They're the most prone thing to breaking
3. I would replace the driveshafts as well with real ujoint driveshafts, also, i would keep the stockers as spares and take them with you.
4. Diff covers are good, Engine skid is important, relocate the emissions control box that's underneath in the back to somewhere less prone.
5. tires tires tires. The more aggressive you can stand the better.
[snip!]
[snip!]
Thanks! I was currently more concerned about the undercarriage. A lot of the above-tire stuff I have a good idea of... Well, except that pesky gas issue. :-)
Thanks,
js.
I'll definately check out OME.
Thanks!
js.
