Scratching/Grinding Help!
Old Oct 9, 2020 | 12:45 PM
JKU GUY's Avatar
Default Scratching/Grinding Help!
I currently have a 2017 Jeep Wrangler with a 2.5” lift and 35” tires. Scratching/Grinding sound whenever I start the jeep cold then begin driving. The noise sounds like it is near my front drivers side tire and it sounds like tranny scratching sound or a vibration sound. I have tried revving the engine in neutral and nothing happens. The noise is loud and goes away after I drive down the block and turn a couple corners maybe after it warms up a bit. Its driving me crazy. anybody encountered this before?
Old Oct 9, 2020 | 12:53 PM
rob_engineer's Avatar
Not a chirping sound? Does the pitch change with rpm? If so, could be a belt or a bearing in a pump or idler pulley.
Old Oct 9, 2020 | 01:08 PM
JKU GUY's Avatar
Not really chirping more like grinding or scratching. Might change pitch a little if I slow down but definitly if i nail it after startup it will be loud. Def doesnt do it anymore after driving for a bit. Im just worried its somethin serious
