JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Are shock boots needed? (https://www.jk-forum.com/forums/modified-jk-tech-2/shock-boots-needed-323564/)
GunDude Jul 2, 2015 02:20 PM
Some say it traps dirt, etc. and some it protects shaft. I just put on Bilstien 5100's and can decide whether to keep boot or not! I think the Bilstien 5160's come with out boots as well as Fox shocks. So, keep or remove?
scooby snacks Jul 2, 2015 02:34 PM
I have Fox Reservoir Shocks, no boots.
I say you trash them... :thumbsup:
Emptied Each Pocket Jul 2, 2015 02:35 PM
I removed mine. Pictures of rusted out shafts were all it took to convince me. The boots that came with my 5100s had breather holes (not sure if they all do), but still just don't like the look, personally.
GunDude Jul 2, 2015 03:30 PM
Yep, that is I was thinking. Think I will remove
ckor Jul 3, 2015 10:36 AM
I have the 5100's and just removed the boots. Only had them for a month or so and can already see the dirt build up. Glad I took them off.
unlimited12 Jul 3, 2015 06:23 PM
anyone in an area that uses salt a lot during winter time have any input on the no boots?
ACJK22 Jul 3, 2015 07:17 PM
We have a lot of salt here in the NE. The shop that installed my lift told me they left them off because of the build up from dirt and salt.
Kojack Jul 5, 2015 02:01 AM
I have hard plastic shields on my shocks. They look like boots, but are hard, and left open around the shock body. All the crap runs out, and the shock piston arm is protected from the massive amounts of road salt spray infused with rocks we have here. When I switch out my stock SS, I am rigging this up as well.
jchappies Jul 7, 2015 01:06 PM
No boots for me either, not only do they trap dirt and moisture they seem to always slip off when you flex out and just hang there no matter how tight you get that zip tie.
Maertz Jul 7, 2015 03:24 PM
For most people's use not needed. In high speed /horsepower scenarios like a koh car many will run to protect the 10s of thousands of dollars of shocks and such. But they also don't just plain Jane rubber boots so to speak.
© 2026 MH Sub I, LLC dba Internet Brands
