should I regear??
I have a 4 door with 3.73 gears x model. Right now I have 33s with a teraflex 3 in kit. I pull a small trailer for dirt bikes and looking to get a small enclosed trailer. It is liveable now but worried about the enclosed trailer. Is the regear worth the money, i see northridge has the kits for like 550.00 what gears should I go with , i will eventually go to 35.s when these shoes wear out
With the 4door auto I would definately go with 5.13 if you want to do 35s, especially if you're going to pull a trailer. You won't want to regear twice. I would wait and do them at the same time though.
https://www.jk-forum.com/forums/show...76&postcount=4 |
Originally Posted by jameswill4
(Post 1624554)
... Is the regear worth the money, i see northridge has the kits for like 550.00 what gears should I go with ...
I think you'll be much happier with the Jeep if you go ahead and regear. I was going to suggest 4.88 but if you believe you will be towing a trailer alot, then consider 5.13s.
When I regear for 35's I will probably get 4.88's. I do not tow often |
With an auto I would recommend 5.13s. Better performance and overall drive quality. You will also take more strain off of the overall drive train system as a whole with new gears, especially when towing.
| All times are GMT -8. The time now is 02:02 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
