Solid diff covers.
Old Apr 9, 2010 | 01:26 PM
  #21
Calypso's Avatar
Originally Posted by Piginajeep
depends on the trackbar,
it has a higher fill hole, but you still only need two bottles
I'm running an adj JKS rear trackbar, anyone with that same set up with the Solid diff cover?
If the fill hole is higher, do you still fill to the hole?
Old Apr 9, 2010 | 01:50 PM
  #22
jd1066's Avatar
I have jks adjustables front and rear, and solid covers front and rear - no problems. Do not fill to the holes - only the recommended amount.
JD
Old Apr 9, 2010 | 01:59 PM
  #23
Calypso's Avatar
JD
Thanks. One more concern I found was the E-locker. Do you still have to grind down the inside of the cover to make room for the E-locker?
Old Apr 9, 2010 | 06:03 PM
  #24
JackMac4's Avatar
I think the new ones are already ground for it. It was just the old ones I believe that you had to do it on. I did it on mine, it was no big deal..took 5 minutes with a grinder..so if you do have to do it, no biggie.
Old Apr 9, 2010 | 09:07 PM
  #25
rubydak's Avatar
I have a set of these that need to be modified with a grinder. I've been waiting for new gear install then going to put them on. I was thinking of painting them camo so BFRs won't see then coming and jump in the way.
