SOLID Front Axle Hub Conversion Kit - Available & Installed!!
Remember the fullsized dodge ram 2wd truck uses 5x5.5 wheels,, the steel 16" rims on the j8 were from one of those,, and the factory mags off those trucks are plentiful in the yards,, I'm planning this swap when I get my 44 front axle for my x.. Then I'll epgrade the rear axle shafts at the same time..
Would be nice if there was a set of axles to buy already converted to 5x5.5 with the hubs on front and rubi lockers for bolt in,, buy the time I get to do there there will probably be 60's out,,
Yeah, so did CJ's and older full size 1/2 ton Fords. Good selection of wheels in this pattern.
I am digging up an old thread because I can't find what I am looking for when I search. What is being done to the rear? New axles for 5 on 5-1/2? If I change axles what do you do with the roters so they fit with this hole spacing? Machine?
Are the SOLID conversion kits still available? My JK runs 5x5.5 already I have been debating between a built 44 with these hubs and a built 60. My math puts (I already have a Rubicon so I have a locker that's already geared too). I'd need shafts, the hub kit and a beef up kit for the 44. The beef up kit is 1200 installed and the hubs are about 1200. The shafts and u-joints are about 600. That would make me right at 3K for my front. A new 60 is about $6K. So this process would be about 50% the cost of the alternative.
I do like manual hubs. I've converted all my previous jeeps.
The problem I had was actually finding the SOLID kits.
Call and talk to Matt at Solid, he has answers, he designed the system. You need to have a machine shop bore the rotor center out and redrill the holes.
I recall seeing the center machine requirement in some original on-line posts. The work is pretty cheap at a machine shop.
