someone school me on gearing....please
Old Oct 18, 2008 | 06:53 PM
matt parker's Avatar
Default someone school me on gearing....please
ok, what i want to know is how the different gear ratios in your transmission, transfer case, axles work together to give you your final output.
Old Oct 18, 2008 | 06:56 PM
RedneckJeep's Avatar
The "final output" as you put it is the final output. Regardless of anything else. It does not change. It can be AFFECTED by other things, such as transfer cases, transmission ratios, overdrive ratios, and tire size, but the final drive ratio (the ring and pinion) does not change. If you want something more specific, fire away.
Old Oct 18, 2008 | 07:15 PM
ok, what confuses me is this. if the transfer case has a 4.1:1 crawl ratio, and the axles have 4.10s, would the gears combine for a total ratio of 8.2:1 or would they cancel each other out?
Old Oct 18, 2008 | 07:25 PM
ronjenx's Avatar
Originally Posted by matt parker
ok, what confuses me is this. If the transfer case has a 4.1:1 crawl ratio, and the axles have 4.10s, would the gears combine for a total ratio of 8.2:1 or would they cancel each other out?
4.1 x 4.1 = 16.81
Old Oct 18, 2008 | 07:28 PM
so it is multiplied. got it.
Old Oct 18, 2008 | 07:34 PM
Yup, ronjenx is right on top of it. It all works the same....overdrives, transfer cases and different transmission ratios. When I was drag racing, I used to mess around with my automatic transmission ratios all the time. All my buddies always wondered why my 60 foot times were suck a killer. LOL
