Spacers, offset and widening questions.
Hey guys! Im helping my dad build an old cj5 (which he thinks will rival my jk off-road... Pshhh
. He is about ready to order tires, 35s. Now, because the cj5 is so tiny and prone to tipping (plus it has a v8... Jealous) he would like to widen his wheel base. What is the best way to do this effectively, safely and the right way? Should he buy a rim with a negative offset, purchase spacers or both? We would probably make our own because he owns a machine shop and i run a CNC machine. Ge is looking for 2-4 inches wider on each side. Thanks guys! He says ti give you guys a big ole jeep wave from the CJ community!
A lower offset wheel would be ideal but the wheel spacers won't kill anyone. Since you guys are rebuilding the truck, maybe set some funds aside for wagoneer axles- full size and full width axles.
He owns the machine shop and you run the cnc machine, I trust then that both of you are aware of material properties and could choose the proper strength spacer.
Sent from my DROID4 using Tapatalk
