Specific Trackbar Question
I am suffering with a driver side drift in my 2.5" lifted JKU. My question is whether or not a front track bar will correct this or if I should change both front and rear. I have tried many other solutions such as new steering stabilizer and alignment. I have replaced the upper and lower ball joints with serviceable ones as well as they were death wobbled. Here's one more thing: a while back, while wheeling in Rausch Creek, I got a shop to box weld my rear sway bar bracket, which had cracked. They did an incredible job and turned the OE rear trackbar bracket into a solid chunk of steel. I can still access the rear track bar bushings/bolts to change the track bar itself if necessary, but the bracket itself where it attaches to the axle is not longer a janky rattling POS and is welded onto the axle. Any guidance would be most appreciated. If I let the steering wheel sit neutral, the JKU dives to the left at an extreme angle. This is driving me crazy. (see what I did there) Thank for all your insight, friends. SEE ATTACHED IMAGE.
Rear Trackbar weld.
*update, I believe this is an aftermarket Skyjacker Bracket
Rear Trackbar weld.
What steering stabilizer do you have up front? This sounds like the common issue of having a gas-charged unit installed and it constantly pushing the TR to the driver's side (left as you mention).
You can easily test this out by removing the SS (you'll be ok without one), and going for a quick drive. If it is a gas-charged unit, the problem is they are always trying to expand with considerable force......hence always veering a bit driver's side (assuming the normal mounting position of the left side to the axle and right side to the tie rod).
Ome ss
Another free idea.....have you tried rotating the tires to see if the pull improves any?
Thank you. Unfortunately, I have exhausted free options, but just in case, keep them coming.
#JustEmptyEveryPocket
#Justin'sExpensiveEverydayProject
Do you have any alignment specs by chance? TB's shouldn't affect a pull one way or the other. They're just holding your axle horizontally under the jeep. Jeep should drive straight regardless of if the axle is dead center under there or not. Kind of a curious case here. Did this pull just start recently? No recent changes to the setup?
No to the mods and I will check for straight but my mechanic has not reported anything on tie rod. He did mention the trackbar ends showing some wear...that is loose around the bushings.
