spring install question
Old Aug 25, 2011 | 01:43 PM
blue project's Avatar
Default spring install question
I'm currently running a TF coil leveling kit with stock length bilstein shocks. I am going to be putting on light duty OME springs. Do I need to loosen the bolts on my control arms when I install the new springs? I know it said to when I did the TF kit. I saw a write up on installing the 2" OME lift (same springs i'm doing) and they didnt say to do that.
Old Aug 25, 2011 | 01:53 PM
glwood6's Avatar
I've changed springs three times, including installing OME springs the last time, and I have never fooled with the control arm bolts. I undo the shocks and the sway bar links, and that has always been enough to allow room for swapping springs. Some say to undo the track bar, but I never have had to.
Old Aug 25, 2011 | 02:19 PM
Hows the ride with the OME springs?
Old Aug 25, 2011 | 02:48 PM
nthinuf's Avatar
Yes, you should loosen them, lower it to the ground, bounce up and down on the bumpers a few times, and then re-tighten.
Old Aug 31, 2011 | 02:07 PM
glwood6's Avatar
Love the ride.
