Spring question
Is there anyway to keep my Passenger side coil spring from spinning out of its pocket? I have a 09 X with Teraflex 2.5" coil lift and after I trailride that spring is always out of its perch. I did not know if there is some type of clamp or restraint available.
Thanks
Thanks
Front or back?
What shocks do you have? Are they for a larger lift?
I haven't had this problem (yet). I have received my Teraflex 2.5 lift, but have not installed it yet. (this weekends project).
Found this on Quadratec: http://www.quadratec.com/products/16156_100.htm
I have the Teraflex 9550 shocks that came with the lift. I do wheel disconnected and apparently flexing quite a bit.
I wounder if those clips have to be welded.
Thanks for the replies
I dont have that problem on the JK.
HOWEVER
I did on my TJ. I got grade 8 U-bolts, drilled down through the perch. I havent looked at the perches on the jk to see if that set up would work. Its a cost effective and simple fix if it does though.
Also limit straps would help to save you from topping out your shocks.
HOWEVER
