tarpon4me |
11-21-2017 04:55 PM |
Steering issue
My stock power steering pump was failing so I picked up an AGR super pump and installed it. The Install was by the book. Cleaned the reservoir, installed pump, used proper larger belt, flushed all ATF put and replaced with GM PS fluid per instructions. Slowly worked the steering wheel with the engine off and tires off the ground to get the air out, never letting the reservoir run low.
So, crank it up, power steering is awesome! Go down the road, engine heats up. Come to a stop, power steering is gone. Get moving and the power steering is good again. I've tried everything. Hundreds more cycles with the steering wheel lock to lock, flushing the system again, I'm out of ideas. What would cause the new power steering to stop working at a stop when the engine is warm? I have google searched until im sick of it. I hope someone can shed some light on the subject. I contacted Josh at Steerco and he is suppose to call me back. He assures me his pumps are all tested before they ship and that it's almost impossible to get a faulty pump as a result. I'm not convinced...Help!
