JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Steering knocked off center (https://www.jk-forum.com/forums/modified-jk-tech-2/steering-knocked-off-center-250403/)
Fourtango Oct 8, 2012 08:30 AM
So after rock crawling all weekend my steering wheel is about a 1/4 turn off center. Is that normal? Can I just reset it by adjusting my track bar? The ESP light stays on too so I assume once my steering is re centered that will go away. I searched but couldn't find what in was looking for. I'm sure there is a write up for this somewhere.
Rob 12B1P Oct 8, 2012 08:33 AM
Make sure you check your tow-in.
HogHoden Oct 8, 2012 08:38 AM
It's in the write-ups sticky
• Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
http://project-jk.com/jeep-jk-write-...-end-alignment
Fourtango Oct 8, 2012 10:11 AM
o Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Thanks, the search sucks on my phone
Freewill Oct 8, 2012 06:04 PM
Its always possible you tweaked an axle tube or "C", but most likely it is a bent tie rod or relay rod (AKA drag link). Either way the alignment effort will correct the toe-in and steering wheel center. Its just a question of whether the castor and camber are right when you are done.
© 2026 MH Sub I, LLC dba Internet Brands
