1 Attachment(s)
Originally Posted by lkjk
(Post 4119628)
No panties in a bunch, just correcting your misinformation. Not all lift manufacturers specify 3.5" and then knowingly make their kits to give you more lift, that's just silly
(Post 4119628)
- I'm not talking about coilovers since you mentioned you have those, but I suspect you weren't talking about those.
(Post 4119628)
full armor is full armor, as in full skids sliders bumpers winch...usually recovery gear, no idea what mine weighs but nothing close to stock.
(Post 4119628)
don't get the whole bump stop lift height thing...
(Post 4119628)
I have a 3.5" lift on 35s...do I need that much lift for my tires, nope, can I run bigger, yep....but my bumps are set up correctly and I have that lift height because I have a 4 door and need a better breakover angle. I'm using all my travel and I based my lift height on increasing breakover angle not fitting tires. You can fit 37s on a 2.5" lift. As for the trackbar hitting the frame, what front TB mount are you using?
(Post 4119628)
everything effects everything else - raising the rear TB, raising the front TB, messing with bumpstops, possibly notching the frame...not sure what part of that is confusing.
If your jeep is on the lighter side could will put you up higher than advertised. ( no spare, frame width bumpers, etc.)
The metalcloak 2.5" coils put be up 3.5" fully clothed. It sits at 4" with the top and doors off. Does this happen with every jeep? No, but it happens. Arguing with people on the Internet is like competing in the special Olympics. Even if you win, you're still retarded. Sent from my iPhone using JK-Forum |
