Steering Stabilizer
JK-Forum Founder
305/70/16. Roughly 12 inch wide. I only had the 3/4 spacer in the front at that time. Yes it helped alot. I since then have installed the 2" BB and did not use the track bar relocation bracket and it is almost back to stock handling wise. I am goin to instal the relocation bracket and the 3/4 spacer in addition to the budget boost and see what happens.
I am doing to mods that wayoflife is talking about first. Hopefully they get here soon. If that improves my tracking, I will probably stop there.
I have a friend with an older Bronco. He just put larger tires/no lift and said it turned it into a death machine. He took them back. They told him to do the steering stabilizer.
Thats what I am saying is I first installed the tires with no lift and drove it like that for a few days and decided I couldnt live with the wandering. So with no lift why would it have been all over the road? None of my suspension geometry should have changed right?
JK-Forum Founder
Certainly, wider tires will tend to track more (especially if they are new mudders) but a vehicle with the proper toe-in and caster should still handle well enough. Why you experienced this problem, I'm not 100% sure. However, I can tell you that the factory caster is only ±4.2° which is pretty shallow and that people like doojer had his toe-in off from the factory. Perhaps your JK suspension was off from the get go... maybe not. All I'm saying is that typically, steering handling issues can be caused by any number of things and a new steering dampener is usually nothing more than a bandaid fix for them.
I installed the Skyjacker just to upgrade from a little thin stock one to a more beefy stabilizer. Plus it's "Pretty" I felt no difference from stock stabilizer to the Skyjacker.
I only have (2) > 3/4" spacers up front and I'm feeling a very slight "Wandering", (floats a little), probably just enough lift to change the "Caster" a dab... hey, now I can upgrade to lower adjustable control arms...
JK-Forum Founder
Actually, I'm gonna bet that what you're experiencing is tracking due to the axle shift caused by your lift. If I'm correct, you haven't address this yet with an adjustable front track bar have you? But, I suppose your caster could be off too. Who knows, maybe it's a combination of both. Either way, you would typically need adjustable "upper" control arms to correct caster and not "lowers"
6. To minimize the amount of adjusting you will need to do, try to set the length of your new track bar as close as you can to where it needs to be before you install it. In my case, I just installed a 3" lift and therefore set it to about 9/16" longer than the OEM .
JK-Forum Founder
Eddie, your correct, I have no Adjustable Track Bar yet, so the 1st thing I should do is this. I just read an install article where a 3" needed needed 9/16" longer to get it back to center. So if I round my front lift to an even 2" how do you calculate this. What would I need in length? . Bye the way, my steering wheel looks pretty straight, or it's so little that I don't see it. I just read this below:
