steering stablizer bracket
hi I'm not sure what it is technically called but i need a new steering stabilizer bracket .. anyone know where i could get one .. or if their is a aftermarket one that would work better.. i just need the bracket part.. heres a pic this one is bent. thanks
Check out the relo kit here:
http://www.jeepswag.com/
Might be something to consider.
Took a second look at the relo, and it seems to be a bracket for the wrong end. Oh well, still might be worth looking at.
its bent because its not int he right place. You need to lift up the front end and turn your wheels all the way to the right and left and make sure that the stabilizer still has travel. That looks like damage from over extending. If its stock set up it might have been placed in the wrong spot on the tie rod.
i just figured it would be good to replace it .
