Stiff suspension and the effect of extra weight on it.
Old Apr 22, 2011 | 05:13 PM
Runewolf1973's Avatar
Default Stiff suspension and the effect of extra weight on it.
Will the additional weight of heavy steel bumpers and possibly a winch help at all with lessening the bone-jarring effect of going over bumpy roads with a stiff suspension? I have a pretty stiff suspension and you can feel every little bump in the road. Don't get me wrong though, I still absolutely love driving around in it, bumpy or not, just wondering what effect extra weight would have on the ride quality. Will extra weight help?
Old Apr 22, 2011 | 05:17 PM
I bought the Jeep at the dealership already lifted and with 35"x12.5" Toyo MT's. As far as I can tell, it's a 4" Trailmaster lift...at least that's what it say's on the shock absorbers.
Old Apr 22, 2011 | 05:21 PM
A friend of mine who is pretty knowledgeable with vehicles said it might actually help putting extra weight on it.
Old Apr 22, 2011 | 05:24 PM
isshinryu28's Avatar
Tire pressure
Originally Posted by ECHO
Good equipment , what tire pressure are you running in the 35's?
They are running at 43psi right now. Is that too high? I never really owned tires this big before. That's what the dealer had them set at.
Old Apr 22, 2011 | 05:28 PM
WOW.. I am running 28 in mine.. I would lover it about 13 -15 pounds and take it for a ride..
Just so I know what to expect, will lowering them by 13 - 15 pounds make the tire pressure monitor alarm go off?
Old Apr 22, 2011 | 05:29 PM
rterese12's Avatar
I'm no expert but that seems high check the tire it will say somewhere on your sidewall what the psi should be but search around the forum they probably have a thread on tire pressures as most deflate on trails and inflate after
Old Apr 22, 2011 | 05:37 PM
Oh yeah it will go off.. What you want to do is a "Chalk Test"
Take a piece of chalk and draw a thick line across your tread.. then drive it around town on a dry paved road..
Then check to see if the chalk line is gone = ideal tire pressure, all the rubber is hitting the road..
If it's just gone in the center of the tread = High Tire Pressure & that will wear just that part of the tire away faster and you will get less mileage on those expensive tires..
I would start the Test at about 30 Psi and go from there.. you may evebn want to try it at what you have now just to see how far you are off
Thanks! I'll give that a try. Will the tire pressure alarm go away on it's own or would I need to reset it somehow?
Old Apr 22, 2011 | 06:33 PM
Well, I got an AEV ProCal module that came with the Jeep, just gotta figure out how to use the darn thing.
Old Apr 22, 2011 | 07:43 PM
chknkatsu's Avatar
