Stop Theif!!! Drop that HiLift Jack!
So, I just installed a Rampage HiLift jack mount today and am concerned that someone who knows what they are looking at will just walk right off with it while I am in the store! I was going to drill an additional hole in the base of the mount and use a padlock. Does anyone have any clever Ideas to secure the entire jack from HiLift HiJackers??
Paint it pink, and bedazzle it. No one will touch it then.:what?:
Use a gun lock on it the one that is for auto pistols. That is what i use
Yes, a pistol lock is what I use as well.
Used a cable wrapped around the jack then behind the hood hinge with a pad lock, but after a week the jack started rusting, so now it sits in the garage until I actually need it. The cable was $10 at the hardware store.
Gunlock sounds like a good suggestion! Maybe if I bedazzle the gunlock as well, then that should really be a deterrent!!! Well, judging by some of the jeep colors that have been coming out lately, maybe some ppl might like it!!!:rotflmao2:
Here's how I secured mine on my OR-Fab tire carrier:
http://i1192.photobucket.com/albums/...4-07152526.jpg http://i1192.photobucket.com/albums/...4-07152821.jpg http://i1192.photobucket.com/albums/...4-07152828.jpg :cheers: |
Nylon Lock Washer & Bolt
I had the same jack mount you do and I actually was somewhat worried too about theft. I also had the problem that the bottom securing wingnut would always work its way loose/off while offroad no matter how tight I cranked it down. After my 3-4 wingnut/bolt replacement I finally switched to a nylon lock nut. Yes, I have to use at least one wrench (and a leatherman or second wrench) to put the jack on and off the mount, but now it never rattles loose, and I'm pretty sure anyone who thinks they have a quick score off my tailgate will reevaluate when they realize they need tools.
I used a bolt that was about the same size at the wingnut/bolt that came with the mount. You want it to be secure and keep the base of the jack from moving around (another problem I had with this mount before). Also don't get a bolt much longer than you NEED, as the nylon lock washer won't be easy to just spin on past extra threads. Hope that helps! |
1 Attachment(s)
Originally Posted by Peer
(Post 3161498)
Rustoleum is about 5 bucks per can...! Attachment 354122 |
