Stripping powder coat
Old Aug 20, 2016 | 08:17 AM
Ripa777's Avatar
Default Stripping powder coat
Does anyone know what to use to strip powder coating. Gonna get recoated and the shop wants $300 to strip and $600 to recoat. Seems ridiculously high to me. Thoughts??
Old Aug 20, 2016 | 08:31 AM
Chuck-The-Ripper's Avatar
What's the powder coat on?
Old Aug 20, 2016 | 08:32 AM
Also, do you have an air compressor, if so do you know it's cfm rating?
Old Aug 20, 2016 | 02:23 PM
scooby snacks's Avatar
There are several options... If you want the powder completely stripped then you will need to sandblast it. I just did that today at my powder coater. If you just need to take it down a bit then use 100 grit sand paper. I just did that today too. Use an orbital sander and don't stay in one place to long. Powder coat likes to adhere to anything that's hot so if you sand it too long it will get hot and either ball up and adhere or just adhere.
Sand blasted:
Name:	Powder coat rings.jpg
Good luck.
Old Aug 22, 2016 | 07:57 PM
Ripa777's Avatar
They said they tried to sandblast it but it would not come off. It's on steel bumpers.
Old Aug 22, 2016 | 08:09 PM
maxspongebob's Avatar
These are all solutions that I have found on the web.
Acetone should dissolve it. However you will need a big metal bucket to soak it in.
Oven cleaner.
Goof off Paint stripper. http://www.lowes.com/pd/Goof-Off-18-...mover/50298103
Permatex Gasket Remover.
Caution: Acetone is EXTREMELY flammable. Only use it outside or in a well ventilated area.
Old Aug 22, 2016 | 08:34 PM
In regards to my previous comments, that were never answered, I was going to suggest purchasing a sandblaster and covering the items in air-craft stripper before you sand blasted them. I'm not sure on the going rate of having items sandblasted, but I know you can pick up a decent "diy" sandblaster for pretty cheap, mine has came in handy quite often.
http://www.tractorsupply.com/tsc/pro...rasive-blaster
http://m.harborfreight.com/40-lb-pre...ter-68992.html
Old Aug 22, 2016 | 09:57 PM
Ripa777's Avatar
Originally Posted by Chuck-The-Ripper
In regards to my previous comments, that were never answered, I was going to suggest purchasing a sandblaster and covering the items in air-craft stripper before you sand blasted them. I'm not sure on the going rate of having items sandblasted, but I know you can pick up a decent "diy" sandblaster for pretty cheap, mine has came in handy quite often. http://www.tractorsupply.com/tsc/pro...rasive-blaster http://m.harborfreight.com/40-lb-pre...ter-68992.html
Ahhhhhhh thx U. I don't have an air compressor
The shop said they use a special stripper not readily available to consumers..... Hmmmm I bet it's the aircraft stripper u mentioned
Old Sep 1, 2016 | 08:16 PM
catahoula's Avatar
You can get at any auto paint supply store. I have always had powder coat blasted off before coating.
Old Sep 2, 2016 | 02:34 AM
Mark Doiron's Avatar
Local shop here in OKC uses an oven. Put part in overnight, take out next day, powder coat has all turned to ash. Another one uses a sandblaster. Sand hopper is about 30 feet tall, hose is 4" diameter, and your bumper will be clean in less than a minute or two. Find a different shop that is more efficient.
