SuperChip TrailDash 2 transmission issues
I have a 2013 JK unlimited rubicon with an automatic transand i just installed the Super chip Trail Dash 2.
i intalled the unit and have been testing the different performance modes bit my issue is it is causing some major issues trying to shift. its either not down shifting or it will not shift past 3rd gear. any ideas?? |
Did you change the gear ratio. Even though our 2012 Rubicon's have 4:11 gears you cannot change the gear ratio from the Trail Dash 2 default which is a different number unless you have actually done a gear change. That isn't in the instructions but mine did the same thing, I called Superchips and they said set it back to default and the problem went away.
Here are my notes:
Axle 3.73, said don’t change unless you’ve changed axles. Changed to 4.10. Said vehicle settings have been changed. To revert lockable features to stock select “Factory Reset” under “Settings” in the main menu. Drove it and speedo was fine with 4:10 setting, but I was doing 4500 rpm at 75 rather than 2500 and the paddle shift didn’t work. Reset to Factory settings and all is fine, showing 3:73s again. Called tech and they said the 3:73s are just a placeholder and don’t change the gear ratio unless you’ve actually changed gears. |
bbolander
Originally Posted by bbolander
(Post 4316463)
Here are my notes:
Axle 3.73, said don’t change unless you’ve changed axles. Changed to 4.10. Said vehicle settings have been changed. To revert lockable features to stock select “Factory Reset” under “Settings” in the main menu. Drove it and speedo was fine with 4:10 setting, but I was doing 4500 rpm at 75 rather than 2500 and the paddle shift didn’t work. Reset to Factory settings and all is fine, showing 3:73s again. Called tech and they said the 3:73s are just a placeholder and don’t change the gear ratio unless you’ve actually changed gears. THANKS!! |
Originally Posted by tylergurnee
(Post 4316473)
thats exactly what it was doing so i just leave it stock? did you change the tire size? have you used any of the other modes?
THANKS!! |
that worked!!! THANKS!!
what gas do you run? I run 87 but whn i looked at the crawl mode it said 92 and higher..... does it matter? |
(Post 4316518)
