Superlift 4"
what else would i need to buy if the kit includes...
Kit Includes: * Front Springs * Rear Springs * Front Superlift Superide Shocks * Rear Superlift Superide Shocks * Adjustable Front Track Bar * Rear Track Bar Bracket * Front Cam Bolts * Front Brake Hose Brackets * Rear Brake Hose Brackets * Extended Front Bump Stops * Extended Rear Bump Stops * Front Bump Stop Spacers * Rear Bump Stop Spacers * Anti-Sway Bar Links |
Have heard negative things about the cam bolts. Some lower adj control arms would do you better! Just my $.02
Originally Posted by Rubimon
(Post 121180)
I would on the other hand recomend you go to someone who does know how to weld and have them beef up the welding on the resr track/panhard bar mount at the axle as the factory welds bring the suck. Add a gusset or 2 if you can while you are there. |
Now's the time to order!!!!
4wd Hardware (4wd.com) has a sale going on. You can get 15% off one item. I got the Superlift 4" kit for $532 shipped!!! Reg. price is like $577 plus S&H!! I'm not sure how long the sale is going on though, so you better pull the trigger soon :D . |
oooh. i better jump on that. so with that lift i wouldnt need to buy new driveshafts right? ill be running 37"
Originally Posted by stevenisthug
(Post 121314)
If you have a 4 door you don't have to, at least not right away. I'm not sure about the 2 doors. You're rear d/s angle will be steeper if you have a 2 door. It's hard to say how these shafts are going to hold up to long term abuse. I just read today that Piginajeep's shaft is trashed :eek2: (that came out wrong :rotflmao1: ). He has a 2 door. |
