Suspension solution for a very heavy expedition 2007 JKU
I have a 2007 Unlimited Rubicon that I use for expedition style off-roading and camping. With the modifications I've made and all my gear, it's very heavy. I'm looking for advice on an suspension upgrade that will handle the load (and still be reasonable when unloaded).
Current modifications include 35" tires on 17" aftermarket allow wheels, flat fenders, 1.25" body lift and a steel rear bumper with swing away tire carrier (which also holds two 5 gallon gas cans, a Hi-Lift jack and a shovel). Suspension is stock other than AirLift air bags in the back (which are terrible and fail all the time).
The numbers...
Stock weight with driver and a full tank of gas: 4,860 pounds (2,530 pounds front, 2,330 pound rear)
Modified weight with driver and a full tank of gas: 5,200 pounds (weight distribution unknown)
Expedition weight with driver and a full tank of gas: 5,940 pounds (2,540 pounds front, 3,400 pounds rear)
So, with all my stuff I'm 1,080 pounds heavier than stock (1,070 pounds of that on the rear axle) and day to day driving around I'm 340 pounds heavier than stock. Some of that is the unsprung weight of the larger wheels and tires of course.
Does anyone have a suggestion for a suspension system that would meet my needs? I'm not looking for a lot of lift... carrying capacity is the most important thing.
Thanks!
Mike
The numbers...
Thanks!
Mike
I don't know my weights, Mike, but I run very heavy. I have 2.5" TF coil lift with OME HD springs on the rear, 35" tires. It works for me. Feel free to check out my videos at DigitalByDoiron on YouTube to see what I do and how I do it.
coilovers would be adjustable...
Not sure what part is confusing. The increased weight of the aftermarket wheels and tires is unsprung weight (like the brakes, axles, etc.) and is not carried by the suspension.
Coilovers are an option. Hell, everything is an option!
Do you know which OME springs you have in the rear? Also, why OME out back and Terraflex up front?
Thanks!
Thanks!
Might be way off here, but an extra 1000 pounds isn't exactly "very heavy". I don't think of mine being terribly heavy:
5 37" MTRK's : 365 lbs.
RK arms: ballpark 50 lbs
Front and rear bumpers: 150 lbs.
Skids and rock rails: 250 lbs?
These are all pretty conservative I think (I've never actually weighed them) but that's already 815 lbs before my 270lb ass steps in or throws in tools, recovery gear, and a generously stocked cooler. Throw in 2-3 more people and you're easily to 1500 lbs.
I think the short answer to what would we recommend is almost any reputable lift. Most of them are built with a heavier modified vehicle in mind.
you say 1080 heavier than stock and 1170 of that is on the rear? 1170 can not be a split like that the first number should be larger no?
But yes coilovers would be an easy option. But I agree with others. 1000 is not bad especially when some of that is unsprung.
The OME HD or HD+40 coils would be a good way to go. You could also do the JKS ACOS so you could adjust for different heights for trips and daily driving.
My friend's Jeep. He is all of the way down on the bumpstops in the rear in this image. After this trip, I would go with him to his home in WA and we would replace his rear springs with the OME HD springs. He ordered them from David at Northridge. If you tell David that you have a 2.5" TF lift with too much sag in the rear and you would like OME HD springs to address that, he will get you a set of the correct ones. Sorry, but I'm not a very good person for remembering exact part numbers and such.
