JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Sway in frontend (https://www.jk-forum.com/forums/modified-jk-tech-2/sway-frontend-63665/)
NYJKGUY Dec 3, 2008 11:17 AM
Sway in frontend
has anyone else had this problem after installing a lift kit it hapens while driving going over small bumps in the road or just uneven ground i would like to know if anyone has any ideas
scouter4life Dec 3, 2008 11:23 AM
Are you referring to the Death Wobble? Feels like the wheels are going wherever and you have no control?
guinnessisgood Dec 3, 2008 11:24 AM
Could you be more specific with the problem you have? I noticed after my 2.5' lift that my steering was more touchy and required more concentration on the highway. Then after I added 33' tires bumps seemed to make my steering wheel move more, which a better steering stabilizer would probably help with.
Matt08jk Dec 3, 2008 02:54 PM
Any kind of more aggresive terrain type tire will have that floaty effect, even more so when you start to add more inches to the tire width. The original tires on the X and sahara are much better handleing on the road, just the way it is.
Smoke6 Dec 3, 2008 02:59 PM
Do you have adjustable control arms?
NYJKGUY Dec 4, 2008 02:15 AM
i dont think thats it i had put front and rear track bars in and it went away for about a year and now its back it looks like the front axel is moving left to right i can see scrape marks on the frame from it rubbing
NYJKGUY Dec 4, 2008 02:18 AM
No i dont i have a full traction 3" lift with 35s
wrnglrguy Dec 4, 2008 02:18 AM
Maybe you've got some bad bushings on your suspension components. I would put it in the air and check everything really good.
Smoke6 Dec 4, 2008 05:50 PM
I have fixed CA's too, that may be part of the problem. Is your adj. trac-bar tight?
Lorrel Dec 4, 2008 06:37 PM
The discription you give would make me believe a loose trac bar.
© 2026 MH Sub I, LLC dba Internet Brands
