Swaying while driving.
Well see...... I had a blow out with one of my tires(believed tire malfunction). My dad asked me what pressure I was running and I told him 35. He looked at the tire and said I should be running 50. I TOLD him that that's too much but he insisted that I do it cause the 35psi caused my blow out. YEA RIGHT. He proceeded to fill my tires and I said whatever I'll give it a try. Thanks got the info guys..... I'm going to go let some air out :crazyeyes.
I run 30 to 34 lbs in mine with no issues at all. To my best guess, I figure the tire's rubber compound my be different than others. What tire make to you have and how much weight you're adding by adding aftermarket products. You just have to play with them and get them to ride right by drawing a chalk line across them and reading the line. If is gone in the middle then the tire is too full, if it's gone on the outter edges the tire pressure is too low. If it's gone all the way acrossed the tire then it's properly in flatted. And never fill a tire to max pressure! Hope I helped.
My BFG 37s also at 26 psi. Above 30 they get squirrely. The pressure listed on the tire sidewall is a maximum and the pressure at which you can safely load the tire to it's max load rating which is hugely high.
Mike
Mike
For example, the stock BFGs that come on Rubicons have a max PSI of 50. It's only by looking at the door that you see you should only have them at 37 for a Jeep. Try airing those things up to 50 and go for a ride. Veeery exciting
There's a variety of tricks you can supposedly do to figure out the right pressure, mostly centered around chalking or wetting a perpendicular line across the tire tread and then driving a few rotations in a flat dry parking lot. The line should transfer to the asphalt clearly and evenly. If it's only in the center of the tread, you're over inflated; if it's only on the outsides, it's under inflated.
