Synergy trackbar, sector shaft brace with RK trackbar?
Anyone successfully using this combination or at least attempted it? I have 3" bumpstops on the front that are perfect with my RK 3.5 lift and don't really want to add to them. Wondering if that would be required due to premature TB/shaft contact.
Thanks
http://www.synergymfg.com/instructio...69-V4_INST.pdf
Thanks
Looks like it will fit. I have that on my list in the very near future. So I will know soon enough. I have a RC adjustable track bar now. I like the looks and idea behind the design. In about 3 weeks I'll know for sure. Already have the synergy drag link and tie rod bar. Good stuff. I bought the RC bar because it looks similar and cost much less. It works good and is much better than the stock, flimsy track bar.
Sent from the fast lane while driving one handed.
Further research I found the RK springs contacting the brace was a bigger issue. I ended up going with RSP's V5 brace which was no picnic. I ended up having to grind that down to clear the RK trackbar and send it back for re-powdercoating and move the grease fitting but it's on now and Mike there worked with me to make it functional.
the RK track bar will not work with the Synergy track bar /sector shaft brace.....I sold my RK TB and went with the Synergy TB. I have no spring contact as I use the Synergy springs which are slightly smaller in overall o.d. The Synergy TB/Sector shaft brace made a huge difference in tightening up my steering with 37's
I'm mainly interested in the track bar brace.
I have this exact brace ( minus sector shaft portion ) and 3.5" MC coils and RK track bar all just put on last week and everything clears perfectly.
Is it an issue with adjustable control arms that guys are having clearance issue? I have stock arms and RC drop brackets
Sent from my LG-LS980 using JK-Forum
