synth vs dino oil question
Other than extending the oil change interval, something I will not do, are there any benefits to switching to synth oil? It is a lot more costly.
any help please
any help please
Yeah, it costs a little more.
Synthetic responds to high and low temps better.
There is nothing wrong with good quality dino oil if you change it often, along with the filter.
I would say the biggest advantage to synthetic is the extended change interval and reduced friction. Both are debatable.
Honestly unless you wheel extremly hard or tow regularly no there isnt a huge bennifit (as long as you change oil and filter religously). If you do wheel hard and tow they synthetic is much better at protecting under extreme loads and will not break down or loose detergents as fast.
The recommended oil change interval is at 6k miles per the owner's manual...IMO I would use synthetic & have it changed every 6k miles, if I was using dino/conventional oil, then I would change it every 3k-3.5k miles...I am currently running Synthetic just as a "piece of mind" assurance
5w-20 mineral (dinosaur) oil is 5 weight oil with additives to make it lube like a 20 weight oil at operating temps. A synthetic 5w-20 is a 20 weight oil treated to run like a 5 weight oil when cold.
In the US, manufacturers are allowed to start with a group 3 base oil and refine it enough to call it synthetic. elsewhere, you can't call it synthetic unless it is made from group 4 or 5 base.
as mentioned by the others above, change it 'enough' and it won't matter. Changing at 3k for dino or 6k for synth... costs about the same, no?
time, really cold temps, and severe driving conditions (including lots of real short trips where operating temps aren't maintained for long, if at all) are the enemies of motor oil.
I havent seen this problem on many german or japanese cars, maybe they use better silicone
