synthetic vs wire winch, which is better?
Old Jan 24, 2011 | 11:51 AM
TheScientist's Avatar
Watch these 2 videos and decide for yourself.
syn line breaking
http://www.youtube.com/watch?v=ag08H...eature=related
steel line breaking
http://www.youtube.com/watch?v=m1NnL...eature=related
Old Jan 24, 2011 | 12:02 PM
AveryR's Avatar
Originally Posted by lowrpmtork
mythbusters disproved the broken steel cable cutting someone in half. It would just give you a real bad welt and barely break the skin.
You're going to bring up a crummy discovery channel show that should have been cancelled a long time ago as your argument that that doesn't happen? They use dummies that can't move or react in situations and are made up of way harder material than the human skin. Most of their tests are completely bogus. Until they use themselves to test things, you can't take any of their dummy tests accurately at all.
Also Thumbs up Scientist.
Old Jan 24, 2011 | 12:20 PM
Bustabizz's Avatar
Former Member
Have you ever seen a steel cable break? It is scary. If that hit you would be in the ICU for sure, might not kill you but you would be hurting bad.
Synthetic all the way, much safer, light weight.
Old Jan 24, 2011 | 12:28 PM
BLK08JK's Avatar
Originally Posted by dcharge74
You just have make sure that it is under load when you spool it up. It is a PITA, but IMO it doesn't outweigh how much safer it is then steel cable.
What exactly do you mean by this? How do you spool it under load?
Old Jan 24, 2011 | 12:36 PM
wmphoto's Avatar
You should do this with both Steel and Synthetic... you completely unwind your cable... then you spool (re-wind) it back onto the drum while putting 500-1000 lbs of weight on the cable. This will ensure that the cable is stretched and won't bind when spooled out... It also helps with Bird nesting...
Oh, and synthetic all the way... My dad's Navy budy had a hand amputated buy a steel cable breaking... His story is that he was checking a cable that was under tennsion when it broke... it didn't amputate it right there, but it damaged it enough that it was amputated on the Hospital ship...
Old Jan 24, 2011 | 12:37 PM
Rafi's Avatar
hook up to a tree in your yard or wherever. preferbly with a slight incline. and winch in. have someone in the vehicle, and outside to guide it in nicely
Old Jan 24, 2011 | 12:44 PM
A/C Guy's Avatar
Default Depends on where you live and the terrain.
I bought steel because synthetic will weaken in the desert sun and heat. Synthetic also will get ruined the first time it rubs a rock. If you use a dampener, or better yet 2 dampeners, the steel cable will not hurt you if something fails.
A common mistake that I see is people using a single pull point when attaching the cable. Why not use a 16 foot strap connected to 2 points on the vehicle? That is much safer. Even if 1 point fails, the second attaching point will prevent any whiplash of the cable. Common sense will prevent 99% of winching failures and accidents.
A steel cable can cut someone in half. It has happened near here. But it happened at a concrete forming company. The post tension cables are tightened to 80,000 psi tension. That is a far cry from your 8,000 or even 16,000 lb recovery winch.
Steel for me is best. I always use 2 points when attaching a winch. 2 blankets on the cable give me the added protection "just in case".
Old Jan 24, 2011 | 02:34 PM
Inyo JK's Avatar
Default Wire winch cable
Well if anyone is looking, I have a brand new steel winch cable in my garage. Came with my Warn 9.5i never used. Make me an offer....
Old Jan 25, 2011 | 03:42 PM
JoKer1050's Avatar
syn line breaking
steel line breaking
wow, good vids, and thanks for the advice all
Old Jan 25, 2011 | 03:52 PM
Flash1034's Avatar
Originally Posted by FloBraJK
It all depends on your situation. Synthetic is not the best to use when rocks oppose an obstacle for whatever you're winching. If the rope rubs on the rock, it'll tear and break. And roller fairleads are not the best to Use for synthetic(don't remember where I hear this)
Synthetic floats, lightweight, less deadly, etc.
Cable is heavy, like a rubberband when it breaks, doesn't float, pain to roll up, can fray and cut you, etc......
If you are dragging the cable over rocks, up waterfalls, dersert floor, etc, cable is much more durable. For simply pulling vehicles out of a mud hole, synthetic is fine.
Flash
